BX2350 Dash Digital Display Hourmeter & Tach
   / BX2350 Dash Digital Display Hourmeter & Tach #1
stu1951
Goderich,Ontario. CANADA
BX2350
I just lost the digital display to show me my RPM when running........... And also my Hourmeter when I just have the key in the ON position.
It was working fine.............Then after I changed my oil when I was looking for the hours it was blank. Any Ideas...........fuses are Ok
Thx Stu
A bit more information on the blank digital display on my BX2350. Prior to changing my oil I pressure washed the tractor........maybe some water got into somthing it should not have. I did not check the seperate slow blow fuse. What part of the electricial system does the slow blow fuse control?:)
   / BX2350 Dash Digital Display Hourmeter & Tach #3
There was a recall for these, but if your tractor was purchased in the last 18 mos or so then you probably already had the new one. Mine went blank periodically on my BX24 and has worked great since it was replaced.
Truck Flatbed (A50121)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2025 Icon Electric Bike (A50324)
2025 Icon Electric...
Tallman 6" Water Pump (A50774)
Tallman 6" Water...
2013 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2013 Ford F-450...
