BX2350 Cat 1 hitch size question?
   / BX2350 Cat 1 hitch size question? #1
planesmith
Minneapolis
BX2350
I am waiting to get my new BX2350 and I am looking at adding a 3ph receiver hitch.
Does the BX2350 have the standard 26" Cat 1 setup or the 20" Cat 1N?
   / BX2350 Cat 1 hitch size question? #2
it is a standard cat1
   / BX2350 Cat 1 hitch size question? #3
planesmith, I am not sure which the BX2350 uses. I just went through this last week with my BX24. It uses the CAT 1 N (Narrow) as it will not spread far enough to accept the full width of a CAT 1.
I was thinking all BX's were the same.
Marv
   / BX2350 Cat 1 hitch size question? #4
Ive been TOLD...and I have READ...BOTH ANSWERS..? So I really dont know..but I can say this much. I saw one just a few days ago sitting on the dealers floor when I took a friend to the Kubota dealer to get filters etc...and I happened to look at it ( I love the physical size) and even though they didnt have anything hooked to the back...it sure looked to me that the lift arms were wider than 20 inches just siting there!
Whether they will spred to handle a 26" CAT 1 impliment..?...no idea..but they were wider than 20" sitting idle.
Well so far thats 2 votes for 26" and one vote for 20". I will be at the dealer tomorrow and will bring a tape measure. In the mean time the polls are still open for voting::D
   / BX2350 Cat 1 hitch size question? #6
I have a 48" rotary cutter, box blade, and 60" yorkrake, all with standard 26" cat 1 3pt hitch spacing and it hooks to them all. The only issues i've had were the lower pins on the cutter had to be lowered. my lower links were 3/4 raised with it still on the ground. I remove the sway control links at the clevis for installation, you may run into width issues if you only back off the turnbuckles.
   / BX2350 Cat 1 hitch size question? #7
Having just been through this, here is what I know or think I know. There are two cat 1 hitches in widths 20" and 26". Both will fit on your tractor but the common is 26" and the only way to go if you want to use a quick hitch system in the future. Almost all attachments and the snow blower you purchased use 26"
Just to confuse thing a little more there is a cat 0 20" also but it requires bushings to fit a cat 1 tractor.
   / BX2350 Cat 1 hitch size question? #8
26"will fit, 20"for receiver is the way to go on your BX,With 26"you will have issue's with raising some eqipment high enough with this set up.The eqipment made for narrow set up works well with no modifacations.I have purchased both kind's,depends on eqipment kind and make how it will work on your BX.Ask here before you buy 3pt attachment's most likely someone has tried it or is using it and will let you know what they think. I can tell you from using one buy the 3pt receiver for the 20" you will be happy.Enjoy your new WORK machine.
   / BX2350 Cat 1 hitch size question? #9
Don't forget that with some attachments the pins can be reversed so that they point inwards. This way the 3PH arms don't need to be spread nearly as far apart when hooking up.
   / BX2350 Cat 1 hitch size question? #10
I'm not sure we are on the same page here. On my BX the draw bar width has no effect on the height 3ph can be raised. Enclosed picture is a 26" draw bar with a FunkworksZ attachment. Test this for yourself when you go to your dealer bring a tape measure.
attachment.php
This Funkworkz attachment for the draw bar allow the use of any trailer ball without having the drawbar rotate. I use it because it keeps my tongue attachments away from the tires when I'm not paying attention and turring too tight. (not good).
This company also makes a Reese receiver style attachment for a draw bar which may fit your needs.
"Functional Accessories For Work & Play"
2005 Chevrolet 3500 (A50120)
2005 Chevrolet...
John Deere M Tractor (NOT RUNNING) (A50774)
John Deere M...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
P.T 14' Disc Harrow (A50120)
P.T 14' Disc...
