BX2350 Bulb Sizes
   / BX2350 Bulb Sizes #1
Antique Case Guy
I have a Kubota BX2350 and would like to upgrade all of the lights to HID and LED. Does anyone know of the bulb sizes tat this thing takes. I looked in the manual and all it states is the wattage sizes. The rear Flasher bulbs only have the wattage stamped on the side ofthem and not if they are a 1156, 1157 or what.
Any information that you can provide is greatly appreciated.
   / BX2350 Bulb Sizes #2
This is a good question. I had one of my flashers burn out and replaced it with a 1157 it works alright. But I noticed that it is a little dimmer than the other side. I always was going to check into what the correct bulbs are but never got around to it.
   / BX2350 Bulb Sizes #4
Your bulbs are some obscure model number, but the sockets are the same as an 1156. The problem you may run into is....... will the new bulb physically fit under the lens. I've replaced my headlights and tail lights with 1156 style LEDs. Fronts fit fine...... rears i had to grind out the bottom of the housing for the bulb to fit...... then cover the section i ground out with epoxy, and painted black.
   / BX2350 Bulb Sizes #5
P.S. Remember that if you replace your directional bulbs with LEDs, you will also have to replce the flasher with an LED compatible flasher.
   / BX2350 Bulb Sizes #6
I'd like to know a little more about the objective here. I assume, always dangerous ;), that you are trying to reduce electrical load for other purposes. Please confirm. How much is saved? I would like to install worklights and I see other additions posted by others here that I think might benefit from sharing on this topic. Thanks.
2019 Ford F-250 XL (A50120)
2019 Ford F-250 XL...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
Tires (A50322)
Tires (A50322)
Frontier AB13D Hay Spear (A50120)
Frontier AB13D Hay...
AGCO Sunflower 20' PT Disc Harrow (A50120)
AGCO Sunflower 20'...
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
