BX2350 3PT and MMM Settles
   / BX2350 3PT and MMM Settles #1
AndyinIowa
Central Iowa
Kubota BX2350
How fast do your rear implements or mmm settle on your BX tractors? With about 35 hours onmy BX2350, I notice that the mmm (after lifting to the transport position) will settle enough to start banging against the lift stops in about 60 seconds.
The rear implements settle at least 1" within 3 minutes. They continue to settle at roughly the same rate until the implement is on the ground.
I haven't been closely watching this until this past week. Any others with similar experiences?
IowaAndy
   / BX2350 3PT and MMM Settles #2
My 2350 has about 27 hours now and when at its highest point and park in garage, it will bottom out in about 3-4 days. hjt
   / BX2350 3PT and MMM Settles #3
Have you check your fluid level, or have you changed fluid type. It might be low and creatin a cavitation at the sump, this will fill the oil with air bubbles and injecting air in the cylinders.
   / BX2350 3PT and MMM Settles #4
If your bx2350 is like my bx23, you will have a rate of drop adjustment knob below the seat. If you tighten the knob down and the TPH still drops, the seals on the lift cylinder are leaking by. If it stays up, then sounds to me like a leaky valve. May be time to talk to you dealer in any case. Mine will hold the box blade up all day.
ron
2014 Ford F-250 Extended Cab Knapheide Service Truck (A50323)
2014 Ford F-250...
Lincoln Electric Aspect 375 Welder (A50121)
Lincoln Electric...
Agro Trend 7' 3PT Snow Blower (A52349)
Agro Trend 7' 3PT...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
