BX2230 vs G1800
   / BX2230 vs G1800 #1
ancho
Sumter County FL
Kubota BX2230, L2250
I'm hoping this is a silly question -- but I need some reassurance or guidance from those who have more experience than I do.
I've been running a G1800 for the last 2 years, with a 60" deck from a G1900 (I think the largest deck sold on the G1800 was a 48"?). On our prior property (6ac, mostly flat) it performed very well, but our new property is not as simple (10ac, a few mild slopes but nothing too crazy). Primary duty is mowing and dragging the pastures with a chain drag that weighs somewhere around 150 lbs. Mowing or dragging alone, not a big deal, but doing both simultaneously puts a strain on the machine.
So, I've found what I think is a good deal on a BX2230 with low hours, comes with a 60" MMM and a FEL. My initial thoughts based on the specs (40+% increase in HP, 4WD) would be that it would correct the shortcomings of the G1800 on our property, but before I plunk down the money for the BX, I was hoping to get some feedback on the improvement I can expect.
Thanks!
   / BX2230 vs G1800 #2
Have a BX2230 with a 60inch and a G2160 with the 60inch decks and they both are the same model deck, that is suspended with gauge wheels and the metal belt covers I have friends that are having pulley problems on the 4 bolt flange decks with the plastic covers.
I think the G2160 is real similar to the G1800/1900 but it has the power steering added.
The G2160 has a bit of trouble with the PTO belts wearing and slipping easier and a little less power but it turns tighter then the BX but will get into more places where a ROPS will get in the way and spins the tires easier on hills or wet grass.
The BX2230 does not turn as tight but goes up hills better in 2 or 4 wheel drive and will handle thicker grass before things bog down. The BX does burn more fuel for the same area cut. The G2160 drives more like a sports car where the BX is closer to a truck but taking the FEL off does help a lot and just leaves you with the turn radius to deal with.
Have a neighbor that went from a Deere 420 to the BX2350 and his complaint was the Kubota not having a hopper style bagger.
Also have a 6ft chain harrow that the bx2230 pulls fine in low range along with 5ft rake, 4ft box blade and a 4ft rear 3pt blade.
David
   / BX2230 vs G1800 #3
Go with the BX, Im a happy BX owner and I recommend you getting the same
   / BX2230 vs G1800 #4
Ditto the above. I'm a VERY happy BX2350 owner. It will constantly impress you with what it can do. :2cents:
Dave
Cat DPL40 Forklift (NOT RUNNING) (A50774)
Cat DPL40 Forklift...
2015 GMC Yukon XL SLT 4WD SUV (A50324)
2015 GMC Yukon XL...
John Deere 250 Skidloader (RUNS) (A50774)
John Deere 250...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
