BX2230 parking brake
   / BX2230 parking brake #1
RaydaKub
Veteran Member
Rochester, MN
Kubota BX2230
Last week, I forgot to release my parking brake. The hydro was whining and the tractor accelerated slowly while I was mowing. I only ran with the brake engaged for about a minute, but it was enough that I could hear it on the engine and hydro.
Yesterday, I was working on taking down a tree. It's a heck of a slope and I found I couldn't get the brake to hold on the hill. I ended up having to lock the brake, drop the edge of the bucket hard into the dirt and just for good measure, set my 3ph weight bar on ground to drag.
So do I need to just start doing leg presses to be able to push on the brake harder? Or should I try to shorten the rods a turn or 2 on the brake? Or am I asking too much from the brake to hold the whole tractor on a 20+ degree slope?
   / BX2230 parking brake #2
I'm guessing that if you were able to move the BX with the parking brake set, then it probably needs adjusted anyway. If I recall, it's an easy adjustment. That little foot lever is a bit tricky to operate as opposed to a handle. Holding on your slope should work okay I'll bet, as long as you are mounted.
   / BX2230 parking brake #3
On my BX with the parking break set it acts like its in neutral when I press the pedals.
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
New/Unused 7ft 10 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 10...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
