BX2230 HYDRO LEAK
   / BX2230 HYDRO LEAK #1
redneckarchery.com
I HAVE A BX2230 WITH 275 HOURS ON IT AND NOTICE SOME FLUID LEAKING AFTER DOING SOME VIGOROUS BUSHHOGGING. TRAILER IT AND BROUGHT IT HOME AND DECIDE TO GO AHEAD AND REPLACE THE FLUID AND FILTER SICE IT WAS GETTING CLOSE. THEN I REMEMBERED THAT I HAD DONE REPLACED THE FLUID AND FILTER AT ABOUT 150 HOURS WHEN SOMETHING PUNCTURED MY FILTER. SINCE THE FILTER WAS NOT THAT OLD I DECIDED TO LEAVE IT ON. AFTER REPLACING THE FLUID IT STILL LEAKS BAD. I CAN CUT GRASS FOR 30 MINUTES AND HAVE A 8" PUDDLE AFTERWARDS. I HAVE CHECKED THE VENT TUBE ITS FINE. I HAVE CHECKED THE STRAINER AND ITS IS FINE.
COULD SOMETHING BE IN THE OLD FILTER THAT IS MAKING IT LEAK THIS WAY. LOKING FOR SOME POINTERS HERE IF ANY OF YOU HAVE RUN ACROSS THAT BEFORE. IT LOOKS LIKE IT MAY BE COMING FROM THE VENT TUBE AND RUNNING DOW THE SIDES. I HAVE CHECKED ALL THE FITTING AND HOSES THAT ARE VISIBLE.
THANKS
Dump Box Truck Body (A52377)
Dump Box Truck...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
