bx2230 flashers
   / bx2230 flashers #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
Washed the Bota today and noticed the flashers started and decided to never stop. Had to unplug them before I put her in the garage after a quick wax job. For some reason I would think that the dash lights would be water proof. Should I assume the switch or is their something else I should check before I replace?
   / bx2230 flashers #2
Unfortunately thats normal, changing switches won't stop it. I've had to pop the switch out a few times and flipped it over to drain & dry for an hr or so.
Some have drilled small holes in the bottom of the switch to help them drain and others have filled the switch with dialectric grease but the best bet is to avoid direct water pressure on them.
   / bx2230 flashers #3
There are postings on the form covering this issue. Basically, you can get replacement switches that are marine grade that are more water and dust resistant. I recently ordered a set and they snap in the same dash cutouts as the origional switches when I got tired of the lights comming on at various times by themselves usually running the battery down before someone noticed.
The switches are: ANCOR SURF 'N TURF SWITCHES
The manufactures website is
http://www.ancorproducts.com/whats_n.../homepage.html
and I was able to buy them off of Amazon.com
Amazon.com: Ancor Marine Grade Electrical Surf N Turf Rocker Switch: Sports & Outdoors
You will need 1 # 557026 double pole / double throw switch
and 2 # 557110 single pole / single throw switches.
These will replace the switches currently in the dash. The old ones have a plastic spring catch that looks simular to the new switches. I just reached under the dash, pressed one side in with my finger and pushed up until the switch popped out. You will need 3 new spade quick connectors as the new switch has a different terminal configuration and you will have to remove the big plastic connector that plugs in to the old turn signal switch as it won't fit on the new switch. Just make sure that you note the wire colors and place the wires in the same place on the new switch. The switch change is not hard and will probably take only about 20 minutes tops. They also look good in the dash.
While you are under the dash, you may also find a bulb loose that is dangeling out of the wire harness. From what I understand, it is not used on US tractors and can be put in the middle socket of the second row (just in front of the switches) of 3 light sockets or just left dangeling. The wire harness is common among several models both US and foreign, and the light is for the HST overtemp sensor which the US tractors do not have. Why, I have no idea.
Hope this helps,
PhilD
   / bx2230 flashers #4
now were talkin..thanks guys..i hate not havin somethin werk on a tractor i bought brand new..just cuz i washed it..altho i have nevr waxed it!:thumbsup::laughing::laughing:
New/Unused CFG Industrial XZ20R Mini Excavator (A57453)
New/Unused CFG...
Jumbo Quartz Slab 127.5" x 63.75" (new/unused) Est. Retail $2,200 (Pickup Location: Atascadero, CA) (A59225)
Jumbo Quartz Slab...
IRanch Mini Excavator Wood Grapple (A57149)
IRanch Mini...
JCB 8029 CTS EXCAVATOR (A52709)
JCB 8029 CTS...
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
1652 (A58375)
1652 (A58375)
