Pat's Easy Change BX2230 and the Pat's Easy Change System
   / BX2230 and the Pat's Easy Change System #1
stevenw
Rochdale, MA
Kubota BX2230
BX2230 and the Pat\'s Easy Change System
Folks,
I have been going back and forth with e-mails with Pat (Pat's Easy Change System) as to whether or not the Easy Change will work on my Kubota BX2230.
Pat replied with the following:
Pat Greenwell MFG. [mailto:patrickg@bbtel.com] Yes it will work on your BX2230 with the standard lift arm and if it has extendable lengths in the lift arm it will take 3 1/2 inches. Thanks Pat
I responded with this question:
Pat, You mention if it has extendable lengths in the lift arm. Do you know if my BX2230 has that? It is a stock set-up. Please advise. Steve
and his reply was:
Pat Greenwell MFG. [mailto:patrickg@bbtel.com] Steve: Some tractors come with that option. I don't know if your tractor came with that option. Thanks Pat
So, my questions are, does anyone know if the BX2230 comes with the extendable lengths in the lift arm? And...what are extendable lengths in the lift arm? Does anyone have this system on their stock BX's?
I apologize if this is a stupid question.
Please advise,
Steve
   / BX2230 and the Pat's Easy Change System #2
Re: BX2230 and the Pat\'s Easy Change System
Stephen, I'm sure that the 2230 lift arms are the same as the BX2200, at least the ones I've seen look the same, and the Pats Quick Hitch works really well on the BX 2200. If you have the original stabilizer adjusters which are turnbuckle, get the lift arm separators that Pat has to hold the lift arms at the correct width when you back up and hook to the impliment. You'll probably have to remove the separator after you get hooked up, especially if you're going to use an impliment thea uses the pto shaft. Hope this helps.
   / BX2230 and the Pat's Easy Change System #3
Got my Pats today, his shop is in a word AWESOME! I will be posting photos and all later, but now I have to install them.........
   / BX2230 and the Pat's Easy Change System #4
One thing to watch is the thickness of the spacers is different. When I was cleaning up after installation, I discovered that I had two different thickness of spacers left over, so had to redo it.
Ron
Danny,
Give us the blow by blow details if you can.
Thanks /forums/images/graemlins/smile.gif
   / BX2230 and the Pat's Easy Change System #6
I had one GREAT advantage, I was there where they make them and they showed me what to expect when installed. They have a model of the arms it works on. Installation was a breeze, went on fine, used the thinner of the spacers for my BX 2200. Got them on a lined up with the arms as far out as I need for my tiller and rake. Adjusted them for square with the easy to use adjustors. Backed up to the tiller and after getting the width right, cut a piece of plastic pipe to hook on and hold the arms open, snap snap, right in place. Extended the top link and hooked up the PTO shaft. I was wondering about the extra length needed for it, but all was good. It even made hooking the shaft up easier since I now have more room. Worked fine.
Taking off is just as easy, open the latch, hold it open with the holder provided and drop the arms........done.
Now to the rake. Real close to same width etc., but the rake weighs a lot less, so I have to add some weight (push down on it) to get it to latch. Hooked up the top link and away we go. Have not taken it off, since wife called for supper.........some things do come first.
   / BX2230 and the Pat's Easy Change System #7
Another shot of the system
   / BX2230 and the Pat's Easy Change System #8
Another shot, with the rake angled.......It has room to turn all the way around
   / BX2230 and the Pat's Easy Change System #9
One more, closer to the real reason anyway
   / BX2230 and the Pat's Easy Change System #10
This one needs some adjustment, but I dont think it is a terrible thing.
Land Honor Quick Attach Accumulator Grapple (A50514)
Land Honor Quick...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
(INOP) 2022 JLG SKYTRACK 12054 TELESCOPIC FORKLIFT (A51242)
(INOP) 2022 JLG...
**INOP** 2007 KOMATSU WA320-5L WHEEL LOADER (A51242)
**INOP** 2007...
