bx2230 3 pt wont go up
   / bx2230 3 pt wont go up #1
selkplitt
central Pa
2018 B2601
on my 2230 with 410 hours, the 3 point will not go up and release lever automatically. it goes about 1/2 way up and then stops but won't release the lever. Then I move the lever and again and it goes up more, but not all the way, finally, if i hold the lever, it will make it all the way up. the fluid is full. Anyone have any idea what could cause this?
thanks
   / bx2230 3 pt wont go up #2
thanks
Have you looked at the ontrol linkage on the lever. Sounds like you may have a roll pin partially sheared so that it only occasionally moves the lift valve spool. I presume steering and other functions are operating correctly.
thanks, i will check that out. what i didn't mention is that the lever stays in the up position, and you can hear that it is trying to go up, i then return it to nuetral and then up again and it will move up a couple of inches. and then i repeat the process.
thanks again for the input.
Agway Bale Accumulator (A50515)
Agway Bale...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52128)
2007 Freightliner...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52128)
DeeZee Crossover...
24' Free Standing Livestock Panel Swing Gate (A50515)
24' Free Standing...
Kuhn SR108 Speed Rake (A50515)
Kuhn SR108 Speed...
Bush Hog Mod. 300 - 14 3 pt Blade (A50514)
Bush Hog Mod. 300...
