bx2200
   / bx2200 #1
miker2702
Bronze Member
east tenn
bx2200
would a 5 foot bushhog be to much?
ONLY would be used to mow about 2.75
acres of field ? maybe a 4 foot would be more realistic.
   / bx2200 #2
I like the 42 or 48" width for tractors that size.
   / bx2200 #3
48" would be the max for a light duty. I run a 40" heavy duty Gearmore on my BX2200. It cuts most anything, 14' weeds, even clusters of 2" poplar sapplings, without slowing. Very dense broom grass is the only thing that lugs it a bit.
I like the Gearmore also because the width of the chassis is the same as the tractor. This way, I can see that if the tractor will fit between 2 trees, then the cutter will fit with the same amount to spare as it trails behind.
Available brush hog widths that will work on a BX are 36", 40", 42" and 48". The Gearmore is the only HD model that I know of. All others are LD. I cannot recall any Medium Duty models in these sizes, though there may be some 48" HD and MD that are slipping my mind right now.
If they existed, I think a 54" light duty, and a 48" medium duty could work on a BX with a 22-23 hp engine, if you were just cutting hay. A BX with 15 or 18 hp engine would probably do best with a 36" LD. A BX2660 might be able to get by in hay with a 60" LD.
The best of luck in your decision!
2014 Kia Sorento SUV (A50324)
2014 Kia Sorento...
NEW 23hp Land Hero Stand Up Skid Steer (A53002)
NEW 23hp Land Hero...
2017 JLG 1932R 19ft Electric Scissor Lift (A50322)
2017 JLG 1932R...
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
2018 INTERNATIONAL LT625 SLEEPER (A52141)
2018 INTERNATIONAL...
CAT Skid Steer (A50322)
CAT Skid Steer...
