rbarker
Platinum Member
BX2200 won\'t start in cold
It dipped down below zero last night and the tractor is in a Cover-it shed in the back yard. I usually leave the door open cause it's a pain to roll up and down so it got the full brunt of the cold last night. Luckily I don't need the tractor but I thought I'd give it a try to help take my mind off the sudden death of my Brother last night. Held the glow plugs in preheat for about 30 seconds and cranked but nothing except greyish brown smoke. Many more tries with the glow plugs and all have produced no joy. The motor will sound like it's starting as long as the key is engaged but take away the starter and it stops. I'm charging the battery now, although that's not the problem, and I have closed the door to the Cover-it which has increased the temp inside. I also went and got some product called 911 and a fresh load of deisel fuel. I think the old fuel is winter blend but I can't remember. It was not gelled in the tank when I checked. I know the new batch is winter blend and it took between 2 and 3 gallons. My next step is to try to warm things up in there some more and see if that helps.
For those of you on the fence about a block heater... DO IT! I wish I hadn't let the salesman talk me out of it when I bought the tractor last year. He said I wouldn't need it where I live. BZZZZZTT...Wrong!
Any other suggestions out there besides what I've tried already? I'm not desperate enough to crawl under the thing and disconnect fuel lines etc. It's supposed to get even colder and the freeze is looking like it will last another week!
