BX2200 White Wire In Engine U Got One?
   / BX2200 White Wire In Engine U Got One? #1
NY_Yankees_Fan
Veteran Member
Warren County, NJ (60 miles from NYC)
Kubota BX 2200
Any idea what this white wire with the connector does? Do you have one too? Did mine disconnect from somewhere? Any ideas??
   / BX2200 White Wire In Engine U Got One? #2
I have the same one; also not connected.
Thanks for posting a question about this; it'll be bugging me too...
   / BX2200 White Wire In Engine U Got One? #3
Same here....I looked all over and there does not appear to be a mate to it....everything seems to run normal. Guess it must be that they use the same harness for other models.
   / BX2200 White Wire In Engine U Got One? #4
This is normal, mine has it too. If I remember correctly, the wiring harness is used on multiple models. I think the wire goes to a fuel control device on the 1800's. I once inquired after delivery, as was told this.
   / BX2200 White Wire In Engine U Got One? #5
I also have the same wire/conn on my 2200!
   / BX2200 White Wire In Engine U Got One? #6
</font><font color="blue" class="small">( Any idea what this white wire with the connector does? Do you have one too? Did mine disconnect from somewhere? Any ideas??
)</font>
The wiring diagram in the WSM shows a white wire that connects to the fuel solonoid on the D722 engine (BX1800).
That would be my guess. /forums/images/graemlins/confused.gif
   / BX2200 White Wire In Engine U Got One? #8
Just to confirm, my 1800 has it connected to a solenoid that appears to be for fuel as stated. Amazing what a few good minds can figure out /forums/images/graemlins/grin.gif Of course I had to run right out and check when someone said it was used on an 1800.
2015 TYRSOL PNEUMATIC TRAILER (A45333)
2015 TYRSOL...
John Deere 6068 Engine (A44502)
John Deere 6068...
2009 INTERNATIONAL 4300 UTILITY BODY TRUCK (A43004)
2009 INTERNATIONAL...
2023 AIRMAN PDS 100S T4 (A45333)
2023 AIRMAN PDS...
2017 INTERNATIONAL LF687 (A45046)
2017 INTERNATIONAL...
2011 CAT 336E L EXCAVATOR (A45046)
2011 CAT 336E L...
