Grading BX2200 w/6' angle blade
   / BX2200 w/6' angle blade #1
okie350
Mounds Oklahoma
L3010 & BX2200
Is a 6' angle blade to much for a BX to handle? mainly for snow / ice removal and light grading. any one use this set up? any Pics?
TIA
   / BX2200 w/6' angle blade #2
Kubota only offers the 54" and 60" for the BX series. You can always mount any think and get it to work but it easier to find the limit the bigger the blade.
P.S. I have a 60" blade on order for my BX 2350
   / BX2200 w/6' angle blade #3
I have a 60 in Land Pride on my BX 22 and it works fine. You just can't drop it in soft dirt and let it dig to China.
   / BX2200 w/6' angle blade #4
I have the same blade on 1 of my BX1500s.
89229d1194913923-my-2-
   / BX2200 w/6' angle blade #5
TIA
Why are you wanting to put a 72'' blade on a tractor that calls for a 60'' blade?
Because it is the size I have and Im not buying another one. :rolleyes:
I have a bale spear on the L3010 and would prefer not having to change impliments. it gets old after awhile. so now that mowing season is over why not let the BX play ? So I was just wondering if for some snow removal (It does not snow much here) and grading the drive if the BX would be Ok.
   / BX2200 w/6' angle blade #7
Congrats on the Blade.
It's neat.
Hi Guys,
Still have not really heard if this will work. I know it is bigger than recommended, but does anyone have any real world experence? any Pics?
   / BX2200 w/6' angle blade #9
I would venture to say it will work fine, but you will likely not be able to swing it around, unless you make minor mods tothe lift rods, to allow a little more lift on the 3PH.
I use a 6 foot landscape rake on my BX2200 sometimes, simply because I have one, even if it is larger than recommended. I drilled a couple holes in the lift rod bottom forks, as others have done, which gave me a little more lift, and allows me to swing the rake around while still hooked to the 3ph, when I need to do so.
Try that blade on the bx and see what you think. That will give you the true answer for your situation.
   / BX2200 w/6' angle blade #10
Henro said:
I would venture to say it will work fine, but you will likely not be able to swing it around, unless you make minor mods tothe lift rods, to allow a little more lift on the 3PH. you think. That will give you the true answer for your situation.
How about shortening the blade as an alternative?
2014 Yale 3 stage 8500lbs lift solid tire forklift (A53472)
2014 Yale 3 stage...
2008 CATERPILLAR 320D L (A52472)
2008 CATERPILLAR...
2022 KMC 21-37-HD LOT NUMBER 177 (A53084)
2022 KMC 21-37-HD...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
Kubota Salt-Spreader (A52384)
Kubota...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
