bx2200 try out
   / bx2200 try out #1
charliek
WI, USA
Kubota BX2200
my dealer let me demo the bx2200 over the labor day weekend and i put about 17 hours on it. afterwards, i feel like it's the machine i need. i have 27 steep acres that i'm taming a little bit and intend to grow grapes on one of the south facing slopes. the bx worked fine bush hogging with a 48" bush hog and cut the lawn nicely w/ the MMM. i think i would use a FEL and i need a method to remove snow. the blower appears too expensive for now so i thought i would try out the rear blade. my drive is about 650 ft of gravel. i also hooked a trailer to the BX and hauled around about 600 pounds to test the traction and strength and it did well. i
will use the trailer for hauling firewood out of the woods.
at this point, any input is welcome. i'm about ready to pull the trigger.
thanks,
charlieK
   / bx2200 try out #2
Go for it, Charlie. 17 hours should be enough to know whether you like it, and sounds like you did.
Bird
   / bx2200 try out #3
I think you'll really like the stability of the BX. With a 650 ft drive, I'd be thinking about a front blade, especially if the drive is on a slope. It just seems that driving backwards that much would be a literal pain in the neck -- nor would it be as safe as driving forward.
Huck
2017 Ford F-650 14ft Mason Dump Truck (A46683)
2017 Ford F-650...
10-16.5 Forerunner SKS6 Tires (A49251)
10-16.5 Forerunner...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A46684)
2015 Chevrolet...
Trailer Axle (A49251)
Kubota K7872A 12in Quick Attach Tooth Bucket Attachment (A46683)
Kubota K7872A 12in...
2014 Ford Transit Connect Cargo Van (A46683)
2014 Ford Transit...
