BX2200 Tachometer
   / BX2200 Tachometer #4
I used a tiny tach on my 2200 for years. Worked well. Make sure you clean paint off the fuel line where the sending unit attaches.
   / BX2200 Tachometer
Thanks everyone for the good advice on a tach.
Good to know you have had good service from the Tiny Tac.
   / BX2200 Tachometer #7
I have one too and never look at it 99%of the time the engine is wide open. Not sure of your application but use the tractor for a bit and just listen to the engine.
   / BX2200 Tachometer
I have been reading post that state the BX2200 reaches max torque at 2600 and drops as rpm goes up. Also, bought this used and max rpm sounds high (>3600). May have been adjusted by previous owner.
2008 Bobcat S250 Skidloader (RUNS) (A50774)
2008 Bobcat S250...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
