FWIW, I just had the whole left spindle go: bearings, grease seals . . . I t was ugly.
then I found I didn't have the impact wrench to it it off, but the guys at local, dependable Hi-way Fuel took it apart, told me about a local (sort of) dealer that could get me parts fast. He and I found out that getting the entire spindle assembly, including blade, was cheaper than getting the parts I needed.
They arrived next day, Hi-Way Fuel put it together and I'm doing the mowing this Memorial day weekend that was needed 2 weeks ago.
Problem: Even though I had my blades sharpened, the center blade is not cutting well, if at all. I double checked and it's edges are facing the right way, it's right side up, and it moves when the others move.
Anyone know what might be going on?
I tried looking at the manual to see if I could adjust it in any way, but it was as confusing as it always was. Is the procedure for setting the mower's adjustments documented anywhere else? In away I cna understand?
