BX2200 PTO Lever problem
   / BX2200 PTO Lever problem #1
Rook54
Hello,
I just bought a new BX2200, 60 MMM, 48 Woods Box, & FEL. I have 13 hours on this unit. I have found that it is very difficult to switch between the various PTO's after engaging the PTO and stopping it. Example, I have the PTO lever selected to the MMM only, I engage the PTO, stop it, and then try to select a different PTO such as the MM and the rear, or just the rear, and I can't get that lever to work smoothly. Now if I hand turn the rear PTO a bit, or move the MMM belt slightly, the lever will work fine. The teeth just don't seem to be matching up. I called the dealer who sent a mech. to my house and he saw what I meant, and then went back to the dealership and found that the 2 other new BX2200's are doing the same thing. He said there is nothing wrong with the machine or gear boxes, it just needs some use to loosen up those PTO gears. Any thoughts?? I have the 3 year warranty, but I sure hate to think something could be done early on to fix this. Maybe it is just new and tight. I have never dealt with PTO's before. Input would be appreciated, since it was all of your input over the last year that helped me buy this fun toy!! :) Your knowledge has been well respected from this end. BTW, this tractor is a workhorse, gotta like that diesel engine.
Adam
   / BX2200 PTO Lever problem #2
Probably just new and tight. Mine was like that most of the first season. Make sure that you are moving the lever to navigate the notches on the lever slot too. The lever slot is notched so you have to push it a bit to each side to move it smoothly between PTO settings. Stops you accidentally disengaging / engaging the wrong PTO I guess.
   / BX2200 PTO Lever problem #3
First,make sure you have the engine at low idle,I have found that if you "slightly" engage the PTO lever and then move the lever for your selection;mm/m+r/etc. this seems to help the gears align a little easier...Also get yourself a can of Aerosol Grease and spray the imputs shafts at the point where they go into the casing...
It just takes a little "holding your mouth just right" and things will engage much easier.
   / BX2200 PTO Lever problem #4
At low idle try selecting, if no go then let the clutch out and then depress the clutch once again, then try to engage the PTO.
   / BX2200 PTO Lever problem #5
No clutch on a BX!
Will
   / BX2200 PTO Lever problem #6
I've had my BX for 2 years now and still experience difficulty shifting between the PTO points. I just end up playing (ur, working) with it until it slips into place. A little throttle here and little PTO engagement there and it all of a sudden simply slips into place. I guess I've just gotten use to it.
Cheers,
Randy
I'll just keep working with it I guess. I'm sure it will loosen up in time. I sure have enjoyed this tractor, it was the perfect size for me.
Adam
72in Large Capacity Bucket (A49251)
72in Large...
New Holland 853 Round Baler (A49251)
New Holland 853...
2013 Ford Edge SUV (A46684)
2013 Ford Edge SUV...
2020 Bobcat T66 Skid Steer (A49251)
2020 Bobcat T66...
TPM 18K Mini Excavator (A49251)
TPM 18K Mini...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
