BX2200 Power Steering Problem??
   / BX2200 Power Steering Problem?? #1
nazud
Indiana
Kubota BX2200
I have a BX 2200 with about 225 hrs. The last few times I have mowed I have had a hard time controlling the tractor. The power steering effort is normal but I have to fight to keep the tractor going in a straight line. Sometimes it behaves normally, other times it requires a lot of tuning back and forth to keep the tractor on a straight course. (Lots of back and forth overcorrecting)
The hydro fluid is full, and the filter was recently changed. Do I have a control vavle problem?
Anyone with any insights????
   / BX2200 Power Steering Problem?? #2
Don't remember the exact cause of the problem, but it has been discussed here in the past. There is a defect in the steering that needs to be repaired by your dealer. Even if the tractor is out of warranty, push them for a warranty repair, since there was a manufacturing defect that causes this. I am certain that some of the other members that have already experience the problem will give you the details and remedy.
   / BX2200 Power Steering Problem?? #4
There was anumber of BX's that had defective power steering pistons. I have a friend that just had his start acting up on his 2001 BX. The dealer is giving him the piston, but he has to pay for the labor.
Will
   / BX2200 Power Steering Problem?? #5
I also had trouble with my steering cylinder, My BX is a 2001. Mine was leaking and i took it back to the dealer and they rebuilt it and when i got it back i couldnt steer it, they had cut a oring when they put it back together. They came and got it and fixed it.
Thanks guys. The problem is the piston in the steering cylinder, The dealer/Kubota is paying for the part(s) and labor, I just need to haul it there and back. Dealer said it was a hit and miss problem on 01' and some 02' BX 2200s. /forums/images/graemlins/grin.gif
John Deere 6215 (A50120)
John Deere 6215...
New 4-235/85R16 Roadguider Trailer Tires (A50774)
New 4-235/85R16...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
