BX2200 overheats
/ BX2200 overheats #21
Well, it's a mechanical device that opens and closes, I see no reason why it couldn't get 'stuck' in the middle between the two states, even though I've never personally witnessed that failure mode. Oh well, don't want to hijack the thread over this! ;-)
- Patrick
/ BX2200 overheats #22
</font><font color="blue" class="small">( I had a ’69 Dodge Charger with a flex fan which required a lot of power to turn. When out on the highway the temp gauge would indicate just below HOT. )</font>
This is the first time I've heard of one of those in many years. I assume you're talking about the same thing I put on my '68 Roadrunner when the fan clutch went bad. A new fan clutch was expensive, so I put on a green fiberglass fan with sharply curved blades and as the RPM increased, the blades tended to flatten out. I never had any problem with overheating, and the only time the gauge would rise a little higher than normal was during extended periods of running in excess of 100 mph.
/ BX2200 overheats #23
</font><font color="blue" class="small">( ................ the only time the gauge would rise a little higher than normal was during extended periods of running in excess of 100 mph. )</font>
Were you the chaser or the chase E??????? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ BX2200 overheats #24
</font><font color="blue" class="small">( Were you the chaser or the chase E??????? )</font>
Actually, neither. /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif It was in a place where there was not another human or vehicle in sight, for an amazingly long length of time, other than my wife, who was with me.
/ BX2200 overheats #25
Junkman,
I have seen two different thermostats stuck in the middle. One in a Jeep Comanchee pickup and another in a toyota celica. It can happen.
/ BX2200 overheats
It's been raining all week here. 'probably be next week before I get to test overheating again. Meanwhile I'll check out the belt and do a better cleaning to the radiator.
Thanks all, Joe
/ BX2200 overheats #27
</font><font color="blue" class="small">( Junkman,
I have seen two different thermostats stuck in the middle. One in a Jeep Comanchee pickup and another in a toyota celica. It can happen. )</font>
That is considered "stuck open".... open is open..... closed is closed..... If the thermostat is in the middle position when removed, as you describe, then, when you put it into boiling water, it will continue to open. It will not close at all. When you remove a thermostat, it should always be closed. It needs heat to open. My point is that I have never seen a thermostat that was partially open and wouldn't open the rest of the way when put into boiling water. I have never seen a thermostat that was closed and when immersed in boiling water that would only open a small amount. They either opened fully, or they didn't open at all. If they don't open, they are referred to as "stuck closed". These are the characteristics of thermostats. Manufacturers have for years been trying to create a thermostat that when it failed, would always fail in the open position, but have not been able to do this successfully in a wet system. The only thermostat that I know of that will fail in the open position continually is in the Corvair. That thermostat operates at ambient air temperatures and when it fails, the bellows will fall open.
/ BX2200 overheats #28
Bird,
Actually mine was the type with steel spokes and thin stainless steel blades riveted to the spokes. Those blades had a lot of pitch to them and it roared loudly when revved up. The idea was for the blades to flatten out at high RPM, but the way it roared and made the less than perfect belt slip it seems to me it used more power than a clutch type fan. This fan was installed before I bought the car used, possibly as an attempt to fix the overheating problem caused by the belt which was also on the car when I bought it. /forums/images/graemlins/smile.gif
/ BX2200 overheats #29
Those metal fan blades were originally designed for cars that did towing of trailers or were in a constant service such as a police car. If my memory is correct the trade name was "Flex Blade". A conventional fan blade turns continually at all engine speeds, but doesn't do a good job of cooling at lower engine speeds. At highway speed, it wastes gas. The fan clutch was designed to disengage when the engine got to the higher revolutions of highway speed. This was so the engine would conserve fuel. The highway speed was considered enough to keep the engine cool. The center of the clutch was manufactured from an aluminum casting with fins on it, and had a viscous liquid sealed inside of it. As the fluid in the fan clutch gets hot, it gets thicker making the fan turn faster. The fan clutch is located in the radiator air stream and reacts to the ambient temperature. When the engine is cold, the fan doesn't spin much at all. I used to demonstrate this by grabbing the fan blade when the engine was at an idle and holding it. (back then I took chances that I now consider foolish) As the fan clutch gets hotter, the fan does more cooling. At highway speed, the incoming air would cool the liquid and the clutch disengaged. They are commonly known as a thermostatically controlled viscous fan clutch. When the viscous liquid leaked out, then there was no fan action at all, hence the over heat problem. These clutches have been in use since the early 1960's and I believe that they are still being used. I used to replace them regularly in my shop because they were / are prone to failure with time / mileage. If it failed and you didn't replace it, because it was winter and the engine didn't exhibit signs of overheating, the fan clutch would come apart and take out the radiator. They are also quite expensive for some models.
/ BX2200 overheats #30
<font color="red"> </font><font color="blue" class="small">( My point is that I have never seen a thermostat that was partially open and wouldn't open the rest of the way when put into boiling water. )</font> </font>
The thermostats that I referred to were partially open and would not open further when heated to boiling. After soaking in radiator super flush and cleaning with a wire brush they did open when heated. We are probably spending way too much time on this, but it can and has happened.
/ BX2200 overheats #31
</font><font color="blue" class="small">( ........ We are probably spending way too much time on this.................. )</font>
Ahmen brother......... /forums/images/graemlins/grin.gif
/ BX2200 overheats #32
</font><font color="blue" class="small">( . . . I then took the outer screen off completely and with the inner screen pulled out I looked in at the radiator fins. The fan, which is in front of the radiator, but sucks air forward, had still drawn in dirty air and had imposed a circle of dust on the square face of the rear side of the radiator. I got the vaccuum, stuck that narrow extension up in there and got the dust off the face of the radiator itself. Temp. dropped right back to normal . . .
Good Luck,
Tom )</font>
Once again, saved by Tips on TBN!!
I was mowing last week on a day with 94 deg, high humidity and noticed the temps approaching redline. It never overheated, but worried me. I knew the screens were clean. Found this tip, cleand the radiator up thorughly and temps back to normal!
Thanks again!
Terry
/ BX2200 overheats #33
Hey, I know this is an old post and my tractor isn't a kubota, but I searched for my problem and this thread matches my problems and I'm in a similar area near Houston. Tomorrow, I'm taking the radiator screen off, cleaning out my radiator, checking the fan belt and thermostat. It over heated tonight as I was working. Should I do a full oil change? If the engine is running hot will it degrade the oil? I did a full oil change at the start of the season this year.
thanks
Pete
/ BX2200 overheats #35
Shall we notice this thread has been going for more than 13 years ??
I've had multiple BX2200's overheat -- mine and another familiy member's. Yes, you need to keep the screens and radiator. etc. very clean and clear. Yes, there MIGHT be a stuck thermostat here and there. Mine (with very clean radiator, screens, etc.) gets hotter than it should (toward top end of the scale, near the red) when I mow heavy grass in high outside temps using a 60" deck.
After fooling with this issue for more than 15 years my opinion is that the water pumps are too small and do not move enough liquid per minute. They are fine most of time but do not have enough margin / extra capacity when dealing with hot weather and heavy loads over a lot of time span. I think the radiator is plenty big enough.
I'm still curious -- and get no one who knows -- if maybe the later model somewhat larger HP Kubota 3 cyl diesels have a larger water pump that would fit the older BX2200 ?
/ BX2200 overheats #36
Had this problem with a BX24 with a 60" woods grooming mower (dealer said that's the size I needed), took it to the shop a few times, they changed the instrument cluster only to find out that it wasn't the problem. They never could find the issue, so I took it upon myself to try to figure it out. I noticed how close the battery was to the radiator, so I pull the battery out of the box and set it on the floor board with the leads still hooked up and went mow grass, the temperature never got over 3/4 on the gauge. I fabricated a aluminum box and relocated the battery on the left side floor board. Told the dealer what I did, said he had never heard of doing that. A year or so later I met up with the salesman at a restaurant, he told me he felt like he sold me to big of a mower.
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
(1) WHIRLPOOL WASHING MACHINE (A60432)
(1) WHIRLPOOL...
2010 FORD F550 XL SUPER DUTY SERVICE TRUCK (A60430)
2010 FORD F550 XL...
2013 PETERBILT 587 DOUBLE SLEEPER ROAD TRACTOR (A60430)
2013 PETERBILT 587...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
