BX2200 Oil Leak
   / BX2200 Oil Leak #1
TomPh
Kentucky
BX 2200
I have a BX2200 with 450 hours. It has just developed an engine oil leak at the front of the engine just above the front axle. I am unable to tell if the oil pan is leaking or perhaps the main crankshaft seal. I'm hoping the oil pan gasket is the culprit but fear that the main seal may be the problem.
Has anyone else had any similar engine oil leaks?
Thanks,
TomPh
   / BX2200 Oil Leak #2
That's the transaxle seal, it's on the top of the front axle. Mine had that and luckily I got it fixed under warranty.
I probably overfilled the darn thing since Kubota overlooked stating how you check the dipstick level, meaning I did not know whether to screw it in to check it, or simply sitck it in an out for the correct level.
These details are important for them to mention, as it seems to vary between mfgs as to how you check the fluid level.
I hope that yours is the transaxle too, better than the engine leaking!
2005 International 4300 Dump Truck (A46683)
2005 International...
Kivel 48in Pallet Fork Attachment (A49251)
Kivel 48in Pallet...
1996 PETERBILT 357 35 TON WRECKER (A45678)
1996 PETERBILT 357...
1991 Diamond C 22ft T/A Tilt Car Hauler Trailer (A46683)
1991 Diamond C...
Single Axle Trailer (NO Title) (A49251)
Single Axle...
Wilmar Load Runner 16 Ton Fertilizer Tender (A47369)
Wilmar Load Runner...
