BX2200 Oil Change goof
   / BX2200 Oil Change goof #1
watersjj
Bronze Member
Louisiana
BX2200
Just a note to those who self service your tractor. I was changing the oil filter on my Bx2200 and failed to notice that the old oil filter O ring was stuck on the side of the engine block. After installing the new filter and refilling with oil, I crank the engine and pumped most of the new oil onto the floor underneath the tractor. I quickly shut the engine off and upon removing the new filter, discovered my stupid mistake. /forums/images/graemlins/blush.gif
   / BX2200 Oil Change goof #2
Yes, you always want to check to be sure the o-ring from the old filter came off with the filter. Whether it be a tractor, automobile or generator, the o-ring can remain stuck to the oil filter mount. Sure does make a mess. /forums/images/graemlins/shocked.gif
   / BX2200 Oil Change goof #3
I think we all have done that one once. /forums/images/graemlins/blush.gif how many will admit to starting to put the oil in before puting the drain plug in? /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
   / BX2200 Oil Change goof #4
I did that too. By the way, it also applies to the fuel filter (how do I know?).
My general rule of thumb now is to always look for an O ring for anything that I take off.
   / BX2200 Oil Change goof #5
</font><font color="blue" class="small">( discovered my stupid mistake )</font>
Like the others said, I'll bet we've all done it. /forums/images/graemlins/frown.gif I guess the only good thing is that doing it once teaches a lesson you ain't likely to forget. /forums/images/graemlins/laugh.gif I did mine while I was still a teenager. I was working in my Dad's service station when "spin-on" oil filters first hit the market. In fact, we used to sell "adapters" to change Fords from the cannister type filter to the spin-on type. And yep, I learned that it doesn't make any difference whether it's a cannister type or spin-on type, they leak if there's two gaskets instead of one. /forums/images/graemlins/crazy.gif
Kivel 48in Pallet Fork Attachment (A49251)
Kivel 48in Pallet...
2005 Nissan Pathfinder SUV (A46684)
2005 Nissan...
Scraper Blade (A49251)
International 781 Silage Harvestor (A49251)
International 781...
Quick Attach Loader Plate (A49251)
Quick Attach...
Athens Plow Company Ripper Harrow (A47371)
Athens Plow...
