Loader BX2200 Loader/Hydraulic issue
   / BX2200 Loader/Hydraulic issue #1
Kayleigh
Portland, CT
BX2200
My BX2200 loader recently stopped moving up smoothly. I was pushing fallen branches out of a seasonal pond on my property and the loader suddenly did not want to go up unless I repeatedly pushed the joystick down.
It would å±*ump a couple of inches each time I tried to raise it. All of the other movements of the loader work fine it is just trying to raise the bucket which I am having problems.
I disconnected and reconnected all of the hoses, topped of the hydraulic fluid, and let the tractor run at a medium speed for 20 minutes while I checked for leaks in the system (found none). I then shut it off and moved the joystick around to release pressure.
Still, the loader does not want to go up!
What could it be?
   / BX2200 Loader/Hydraulic issue #2
If you raise the loader and stretch a hydraulic line, the couplers fail. Even disconnecting and reconnectiong does not solve the problem.
You might need a new pair of couplers.
   / BX2200 Loader/Hydraulic issue #3
I had a similar situation on my 03 BX2200. I bought it used with 1180hrs. I found the hyd. oil had not been changes since new. After flushing the lines and changing the oil and filter then disassembled the control valve for cleaning and the problem was solved.
   / BX2200 Loader/Hydraulic issue #4
Reset the QD's or replace if bad.
Thanks all for your suggestions! Going to start with the lines and see what happens!
2016 Ford Transit 250 Cargo Van (A50323)
2016 Ford Transit...
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
2019 CATERPILLAR 236D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
