BX2200 Hydraulic filter, stainer
/ BX2200 Hydraulic filter, stainer #1
rosey
Appomattox, Virginia (Central Va.)
Kubota BX2200
I'm getting ready to change the Hydraulic/Transmission fluid on my BX but before I do I wanted to ask those of you who had NO problem in removing the Hydraulic filter and "strainer", since I read previous posts stating that the filter was difficult to remove. In regard to the "strainer" can anyone advise what size socket is used??....does it (strainer) just unscrew counterclockwise?? /forums/images/graemlins/confused.gif.....any other tips that I should keep in mind while changing the fluid out???...THANKS
/ BX2200 Hydraulic filter, stainer #2
THE filter should be no problem getting off
but the strainer is very tight so make sure you use
correct socket size, i dont recall what size it is. also
make sure you have a big enough container to catch
the hyd fuild , there is quite a bit
2020 CATERPILLAR 279D3 SKID STEER (A60429)
2020 CATERPILLAR...
2023 MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
2023 MORBARK WOOD...
(39) FLOOR TRUSSES (A60432)
(39) FLOOR TRUSSES...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
SWICT 78" SKID STEER BUCKET (A60430)
SWICT 78" SKID...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
