Heavyhook
I purchased a Kubota BX2200d with 279(if the meter is correct) hours? Machine looked to be in fairly good shape. Except the mower deck was covered with oil and dirt. Owner said the Oil had come from leaking hydro hoses that operate loader. Previous owner said that kubota dealer had recently replaced all loader hoses because of leaks and chafing on others.
During pre purchase inspection I had checked the rear dip stick above the pto that supposedly supplies HST transmission, power steering and hydro power to operate the loader. When I pulled the dip out( Engine running) of the hole hydro oil started bubbling out. It looked milky colored like the color of coffee with cream added. No burnt smell. Previous owner stated he had just changed the HST oil ( but filter trans filter was not changed) because of the leaking and replacing of hoses, and it was just air working its way out of the system.
After purchasing the machine and getting home I was doing a normal service on all the tractor systems and giving it a complete going over, but the hydro oil is still aerating and bubbling out the dip stick hole. If I had to guess I would think some oil had been used to top off the hydro sump that had been contaminated with water. I am going to change the filter and HST sump oil 2.7 gallons tomorrow.
I am concerned about excess foaming of the oil, even if the oil is contimated I just do'nt think it would cause this much areation! Is there any where air could be sucked into the system before the pumps? Is the spin on transmission filter under pressure like most spin on types? If so it should show a leak if the gasket was bad or the filter not seated properly?
I have a Kubota B7200 but its a standard transmission model? All the controls seem to work ok but I want to solve this foaming oil in the rear HST/PTO/hydro pump gear box before put it into service? I have ordered a Kubota owners and service manual from Colemans but It will not be here untill next week? Thanks for any input!
