BX2200 Hissing noise
   / BX2200 Hissing noise #1
rmc
Bronze Member
South Jersey
BX2200
My BX2200 has 73 hours and when you raise and low the 3point hitch or the FEL a hissing noise comes from under the seat. I am able to get the noise to stop by moving the 3 pt hitch up and down until the noise stops. But as soon as you use either the hitch or the FEL the noise is back. I think it is coming from the pump but not sure.
Any ideas before I call the Dealer to pick her up.
   / BX2200 Hissing noise #2
That is a good question... my BX 2200 hisses a lot also??? I hope it is not a problem.
   / BX2200 Hissing noise #3
Well it depends on the type of hissing you are hearing. The hydrostatic unit by nature will produce a whine when running. The relief valve will produce a hissing sound when it is bypassing(like when your 3-point reaches max lift or when you actuate your loader to max height or curl). Just make sure that the relief valve is not always on which could be if your auto return to neutral on the 3-point lift is not adjusted properly. To test this pull your 3-point level to the raise position and it should drop to neutral. You should hear the hissing just before it drops to neutral then stop. If it doesn't stop move the 3-point lever to lower it just a bit and listen to hear if the hissing stops, if it does you need to adjust the return linkage.
   / BX2200 Hissing noise #4
When tractors are new they are loaded with paint and we often find that a valve might be sticking a little and needs a little help to find center. All your loader hydraulics and your three point come from under the seat. Try a little penetrating oil on the pivots of the levers and make sure they are returning to center. You are going to here some noise from them when being used.
   / BX2200 Hissing noise #5
I know the sound you are speaking of, I get it quite often. You are right, sometimes moving a lever will quiet it, but it'll come right back when you do something. I think the sound is quite normal, my dad even had it on his L2900, just more evident on the quieter BX. I've heard it from day one, and now 250 hours later, the hydraulics are as strong as ever....I don't even notice it unless I pay attention anymore, just one of those sounds I've gotten used to.
   / BX2200 Hissing noise #6
Could it be jealous neighbors?
jrlichina
I need to check the relief valve then because when I do something similar with the 3pt hitch the noise does stop but returns. Thanks
   / BX2200 Hissing noise #8
With 73 hours I would guess you are still in your warrantee window so you should be able to have the dealer fix it for you. It is a simple adjustment to the 3-point return linkage. If you want to try it yourself I could scan the page from the service manual for you.
Yes can you please scan the page. I would be without the unit for a week or more if I had to return it to the dealer
thanks
   / BX2200 Hissing noise #10
I would also be interested in the info. My BX2200 w/125 hrs hisses once in awhile also.
thanks
Jay
2005 IHI 35N-2 Mini Excavator (A46683)
2005 IHI 35N-2...
Dearborn 12-87 Corn Planter (A49251)
Dearborn 12-87...
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
2005 INTERNATIONAL 4400 BUCKET TRUCK (A48992)
2005 INTERNATIONAL...
Framall 110N Tractor (A49251)
Framall 110N...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A45678)
2020 INTERNATIONAL...
