BX2200 fan belt replacement
   / BX2200 fan belt replacement #1
JW1554
Central Texas
Kubota bx2200
A couple of very loud bangs came from under the hood when I cranked up a couple of days ago, and upon investigation, I found an unhappy 3' snake considerably the worst for wear draped across the fan belt. Then yesterday the fan belt gave up the ghost.(750 hrs). Don't know if I was snake bit or not, but found replacement of the belt to be a royal PITA. Decided not to replace the snake.
The propeller shaft has to be uncoupled to get the new fan belt around the bottom pulley. I was told the seat, floor, speed lever, and propeller shaft, had to be removed, but found I could uncouple the motor end of the shaft and pull it back enough to squeeze a belt between it and the pulley. Has to be done from underneath, of course. It is a lot of work just to replace a belt.
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
Generac 2000 Generator (A50774)
Generac 2000...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2010 Chrysler Town and Country Touring Van (A50324)
2010 Chrysler Town...
Towable Orchard Sprayer (A51691)
Towable Orchard...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
