JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 3,988
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
Has about 800 hrs on it. Bought used from dealer who said it had a lot of water in the fuel system. They replaced all the filters, drained the fuel, cleaned it out and seemed to run fine when bought. After maybe 5 or 6 hours usage it began to bog down and balk at mowing (60" deck.) Struggled to keep going mowing light grass. Additives to absorb water did no good. It seems to run OK for a few minutes when first used and then begins to bog down, refuses to run full rpm, etc. Not overheating at all. Taken to a second dealer. That 2nd dealer says "water in the fuel" and they go thru the same filter replacement and clean out as the first dealer. Ran fine at the dealer. Got it home and before much lawn mowing the same problem is back all over again. Bogs down WAY too easily. Won't run full rpm. The deck is not bogging it down and the deck turns freely. Some smoke but not a heck of a lot. White usually. When having the convulsions the thing shudders very strongly and has even totally quit a few times. Essentially you cannot mow a half acre lot with it without it bogging down, acting unable to continue running and then sometimes totally quits.
All right you guys, what the heck is wrong here ? Suggestions I have heard include: Solenoid/shutoff valve failing and obstructing fuel flow, foreign body in the tank obstructing fule flow, bad injector or injectors, and of course the dreaded injection pump...
