Anonymous Poster
Epic Contributor
- Joined
- Sep 27, 2005
- Messages
- 29,678
This one is for all you BX2200 mechanics out there.
I tried to add a strobe to my BX today - I have to mow along a roadside at one edge of my property and am tired of drivers not seeing me. This is one with a mag mount that I planned to have sit on the top of the ROPS.
To cut a long story short, I tried to splice in the strobe to the two spare wires under the BX seat. I checked them first and they showed roughly 12V on them. I believed these wires were for work lamps so would have been safe. The strobe I have draws less than 1 amp.
Anyway, I spliced in the wires and tried the lamp and no flashes. So then I disconnect everything and check the voltage - the wires now show 0 volts instead of around 12.
Get this - I also can't start the tractor. It turns over and fires a couple of times, but won't run. I checked all the fuses under the dash (by the battery) and also the one in the engine compartment. All are good. Lights all work too.
I thought maybe I shorted something out, but can't find any other fuses.
What happened? Do I need to go red faced to my dealer on Monday? /forums/images/graemlins/blush.gif
HELP!
(Well, that wasn't quite what I said earlier - but you get my drift)
HELP!
