The battery on my BX2200 is not charging and the "Charge System" lamp is always on. I checked the workshop manual and there are a couple of issues possible. One of them is a loose connection. When I removed the panel, I found a hanging set of wires (See picture). The wires are black, white, red/black and red/green. The wiring diagram suggest that this should connect to the "Timer Relay". I can't find the timer relay anywhere. Could this fix my initial problem also. I have no idea what the "Time Relay" is for. The fuses are all good.
Thanks,
Nick,
Thanks,
Nick,
