Bx2200 – 300 hr maint
   / Bx2200 – 300 hr maint #1
wjmst
Strongstown, PA
kubota bx2200
Hello all,
I completed my 300 hour maintenance on my bx2200 this weekend. It took most of Saturday to complete. I do have a couple of questions though.
Oil/Filter – 10w30 kubota brand – no problems
Trans/Filter – SUDT – easy to do
Trans Screen – This was the first time I cleaned this screen. It was pretty tight to break loose, but I got it out without damaging anything. I really recommend getting the 26mm socket to help. There weren’t too many metal shavings on the screen so that was good. I used brake cleaner to clean it off.
Front Axle Oil – No major problems here, I didn’t have a bucket shallow enough, but big enough to hold all of the fluid, so I had to stop and empty my little container a few times. I refilled with SUDT.
Air Filter – Simple and yes, my bracket is broken too, ZIP tie solution for me.
Fuel Filters – No problem, just diesel everywhere. I stilled haven’t come up with a good way to avoid that. I do use golf tees to plug the holes. Maybe I’ll try alligator clips or something next time, but I don’t what to damage the hose.
Coolant – tell me the secret please! I had anti-freeze everywhere! I put a bucket under the drain plug, but the coolant just seemed to shoot everywhere. I flushed it out and refilled with Prestone coolant, but it was a messy job!
I greased everything and sharpened the mower deck blades, but I didn’t have any oil to change the mower’s gear box. The manual says to use 90w oil, but I couldn’t find it at any of the stores. What does everyone else use? I still have some SUDT left over and thought about using that. Any suggestions?
The final item I need to address are my front tires. Both have holes/slow leaks in them. I need to find a better solution. I have used SLIME, but it seems to stop working after a while.
We'll see what happens. Thanks for the help.
Hello all,
   / Bx2200 – 300 hr maint #3
wj,
Welcome to TBN and congrats on 300 hours. I'm not there yet, should hit 300 by late summer (BX23).
When changing fuel filters I use a hemostat on the fuel line (tank side). You can use a scrap of cardboard or something similar to avoid gouging the line.
Although Kubota recommends 'straight' gear oil for MMM gearbox, a good multi-viscosity gear oil would probably be fine. 80-90W is pretty common at auto parts stores. I would NOT use SUDT in there!!
My front tires are nail magnets. So far I am just patching the holes, but seriously considering foam filling. Ask your dealer or a tire shop that handles truck/utility tires about it.
Happy Trails,
Russell
   / Bx2200 – 300 hr maint #4
wj,
Happy Trails,
Russell
Well, I finally cut my grass last night. It took about 2 hours. Most of it was knee high, some places where close to waist high. It was a work out for the bx, but it did very well. I don't think I;ll have to recut it, because it did such a nice job.
Everything seemed to run great on it, so I guess I didn't mess anything up doing the 300 hour maint.
Wes
Wes
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
20306 (A51694)
20306 (A51694)
FAKE (A52472)
FAKE (A52472)
2002 Sterling M7500 Acterra Lift-All LA04C51 51ft Insulated Forestry Chipper Bucket Truck (A50323)
2002 Sterling...
