BX22 the right solution for me? *DELETED*
   / BX22 the right solution for me? *DELETED* #1
MDL
Bronze Member
Kubota BX23
Post deleted by MDL
   / BX22 the right solution for me? *DELETED* #2
Re: BX22 ground clearance?
I personally don't have any issue with ground clearance on my BX22, but I'm sure it could be an issue on some properties. See if you can rent one for a day and travel your property...obviously paying attention to where you are going and what is under you!
   / BX22 the right solution for me? *DELETED* #3
Re: BX22 the right solution for me?
Front end loader and a back hoe can smooth out any humps
for the Bx 22 to drive over ???
Doug /forums/images/graemlins/cool.gif
Thanks for your input, Jim and Doug.
I completely re-wrote this post as I felt I should describe my situation in full rather than many seperate posts. I moved it over to the Kubota Buying area as I thought it might fit more over there.
Sorry for the confusion!
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2018 Ford F-250 Reading Enclosed Service Truck (A50323)
2018 Ford F-250...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
