BX22 Stuck in low
   / BX22 Stuck in low #1
Tdog
Platinum Member
SE Louisiana
BX22
I was using my BX22 today & it got stuck in low range & I can't get it out. I tried pressing on the brake for several seconds, like the Manual says, but that didn't work. So, of course, when I shut it off, I cannot start it again while it is in gear.
I only have 39 hours on the machine.
Guess I'll call the dealer tomorrow 1st thing.
Grrr.
   / BX22 Stuck in low #2
I assume it's a hydro...you might try pressing the hydro forward or reverse a bit to spin the gears some and remove the tension on them (if that's the problem). Gentle with the shifting lever, some of the posts here have stated that they have broken the shifter fork inside the tranny. Good luck and glad it's still on warranty.
   / BX22 Stuck in low #3
</font><font color="blue" class="small">( I assume it's a hydro...you might try pressing the hydro forward or reverse a bit to spin the gears some and remove the tension on them (if that's the problem).)</font>
Good suggestions! The shift lever does seem to get "stuck" from time to time on my BX2200 but moving very slowly (usually in reverse) has cured it for me.
Of course, with the tractor off you're kinda screwed! /forums/images/graemlins/blush.gif
   / BX22 Stuck in low #4
yep u are kinda in a tough spot. ain't going to start if it is still in gear! sometime safety features ain't all that great /forums/images/graemlins/smirk.gif
   / BX22 Stuck in low #5
Happened to me once.
Have a buddy come over and rock the machine back and forth
while trying to shift. I'm sure if you looked around you'll find the no start
switch and bypass it.
   / BX22 Stuck in low #6
Based on mine and others experience, it is simple to fix. The linkage gets a bit balky (especially if new). Hit the linkage on the right side of the trans, under the seat, behing the wheel, with some WD40 or equiv. My '22 was oftern hard to get in and out of both ranges. After a bit of lube, smooth as silk.
Try it, it's a cheap and quick fix.
paul
   / BX22 Stuck in low
Thanx for all the quick replies. I had already tried rocking it, running in reverse, moving forward & then back, but it wouldn't budge. I did get the service manager 1st thing this AM & he echoed techman - - spray the linkage with penetrating oil [I used liquid wrench] & it should go. I also pulled the seat out of the way & got my spare hand in there to help move the linkage. It works fine now - - & it was simiple. Thank goodness.
Gotta comment though, that linkage sure does look fragile. I know they warn you not to force it.
2013 Chevrolet Equinox LTZ AWD SUV (A50324)
2013 Chevrolet...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A52748)
2015 RAM 5500...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2013 Cadillac SRX SUV (A50324)
2013 Cadillac SRX...
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
