bx22 not working right
   / bx22 not working right #1
66goatguy
Can any one help me. i went to lift a load with the bucket, at low speed, it
would not lift it. rasied the idle still woul not. So i stoped. it did not stall the tractor. But now my back hoe will not work.the bucket will lift but is jerky.and
will only go up when joy stick is only pulled part down.The roll works fine as does my power stearing.I checkd fluid ok not burnt.Level ok!.oh yes the bucket will not go down under hyd pressure. So what have i done????.
It has only 100 use,did i hurt the pump????. It all worked fine before i tried to lift the load.
   / bx22 not working right #2
check your hyd quick connects make sure they are all seated
I did check the fitting they are all good.I wonder if i cavated the pump when
i tried to lift the load.I should have stated that it did lift it a little.
   / bx22 not working right #4
They may look connected, but there is one that isn't.
Ok will doubble check,but every thing did work before i tried to lift the load.
also when i move the bucket up and down,doesnt seam to be and pressure in the line.but if i roll the bucke to dump i can see the lines move.
Oh yes should be more clear i was lifting the load with the front loader not the back hoe.but now back hoe 3 point hitch does not work and limmited use of the bucket
Thanks all it was as you all stated a none seated coupler great thank you very much....Funny thing i went to a repair shop to ask what they thought.
And i did not get the answer you guys gave...Go.s to show that these sights help.Again thank you very much. Started to did my hole now got down to 5 feet tonight.Awsome machine it is.......
   / bx22 not working right #8
I'm willing to guess it's probably happened to all of us at least once. Nothing like experience to slove a problem!:cool:
   / bx22 not working right #9
Those quick couplers are the single biggest show stopper for compact tractors. Hands down, nothing is worse. The good thing is that they are easy to fix and they don't cost anything when you find the guilt one. :)
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
