BX22 Hydraulics line
   / BX22 Hydraulics line #1
lrunge
Independence, KY
Kubota BX22
Well it finally happened. My 3 year old BX22 with 420 hours finally broke something other than a air filter bracket and rear plastic light covers I knock off. I was digging out a stump (the last of 6) and just as the tree stump popped out of the ground there was a load pop and and spray from the front of the tractor. A hydraulic hose on the FEL burst. I was using the BH but the FEL hose burst. The hole was right below the connector so I guess it had bent back and forth many times. I have used the BH and FEL a lot. I also put them on and take them off quite often. They do not stay on unless I am using them and I have even taken them off and put back on the same day. The stumps I was digging out were no more than 8-10inch trunk at the max, most even smaller.
Anyway I went to my dealer and he says he can order the parts or I can remove it and take it to a hydraulic place a couple miles away where he has hoses made up. I opted to take them there myself so will pull off the hose tonight and take over tomorrow.
Anyone else have a hydraulic line burst on their BX? Due to age and use, should I pull other lines off and have re-done?
   / BX22 Hydraulics line #2
<font color="blue"> Due to age and use, should I pull other lines off and have re-done? </font>
Last year I had a hose fail on my BL4690 backhoe. Not sure of the hours...probably around 400+. Like you the dealer did not have the hose in stock and I got one made up nearby.
I would not replace other hoses that are still working properly. I have 560 hours on the B2910 TLB now, a lot of them using the hoe, and I am still waiting for a second failure. I prefer to wait rather than possibly waste money replacing functional hoses.
That being said, if I felt like changing the hoses I would. I just don't. It might not be a bad idea to have a long hose available as a temp replacement in the event you have a hose fail when you really need the hoe, during the normal time such things happen, when everything is closed... /forums/images/graemlins/smile.gif
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2002 Mercury 8 HP Tiller Outboard Motor (A50325)
2002 Mercury 8 HP...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
20ft Bumper Pull Equipment Trailer (A51572)
20ft Bumper Pull...
Peacock Lawn Art (A50325)
Peacock Lawn Art...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
