BX22 Hydraulic quick connect problem
   / BX22 Hydraulic quick connect problem #1
SUPERNUG
Bronze Member
MID MICHIGAN
BX22
After taking it off in early December I am trying to reinstall the backhoe for my BX22. For some reason neither of the two quick connects on the backhow will snap in place. The two on the tractor work fine. They had covers installed. Its like they are frozen or something. Any suggestions. There is no pressure in the backhoe system. /forums/images/graemlins/confused.gif
   / BX22 Hydraulic quick connect problem #2
The BH has re-pressurized. This can happen to the FEL or any other hydraulically actuated implement. It happens either because the pressure wasn't completely relieved before the BH was disconnected or just simply because of some atmospheric phenomanon /forums/images/graemlins/shocked.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif, in any case the pressure needs to be relieved before the quick connects will couple.
The easiest way to do it is to use a 3/8ths socket extension and a rag.
Take the blunt end of the extension that normally inserts into a socket and insert it into the female coupling. Take the rag and cover the extension and coupling then depress the extension into the coupling. You should hear the pressure release. Sometimes it takes a good push and others it doesn't take much to push the release valve in. The rag is to keep the fluid from squirting into your eyes and onto your clothes.
Good luck
Volfandt
Thanks that did the trick. Never happened before. It confused me because when I move controls there wasn't any movement so I thought there would be no pressure in the lines. /forums/images/graemlins/confused.gif
   / BX22 Hydraulic quick connect problem #4
If the outside temp warms up so will the fluid and it expands slightly. It'll make it darn near impossible to reconnect without releasing pressue.
2014 Kia Sorento SUV (A50324)
2014 Kia Sorento...
2007 International 7600 Tri-Axle Dump Truck (A50323)
2007 International...
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
