BX22 Hydraulic Leak
   / BX22 Hydraulic Leak #1
Snappy BX
Upstate NY
BX22 (sold) B2920
Hello to all,
I developed a hydraulic leak on my BX22. It leaks while running and seems to be located by the hydraulic control valve (runs down the priority valve)
I have replaced both o rings behind the valve, also the o rings on the pirority control valve. It does not seem to be a pressure leak, the fluid runs down does not spray as it would seem to, if it is pressure leak.
The fluid is at the correct level, the filter has been changed and also the screen checked.
Any thoughts or ides would be greatly appreciated.
2016 MACK CXU613 SLEEPER TRUCK (A52576)
2016 MACK CXU613...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
2017 Ford F-250 Crew Cab Pickup Truck (A51692)
2017 Ford F-250...
