BX22 engine oil level question
   / BX22 engine oil level question #1
bellweather
Platinum Member
Western MA
Kubota BX22
I seem to recall other posts with this question. BX22 manual says 2.6 quarts (with filter change), but dip stick says more required. I'm inclinded to add oil, but concerned about over filling. Any suggestions.
   / BX22 engine oil level question #2
On my BX2200, I would add oil per manual then run it enough to warm it up good then let it sit a while and check again and add according to the dipstick. I never really paid much attention to the final total.
You are right, you sure don't want to over fill.
   / BX22 engine oil level question #3
If the engine has not just been running, and the oil is "settled," fill it to the full mark on the dip stick. It holds very little oil anyway, so it should have as much oil as possible without overfilling.
Around Christmas, I changed the oil, and let it drip a pretty good while, but then I went to work on something else on the tractor. While doing that work, I kicked the container out of the way (accidentally.) After a long period of time passed, probably around two hours, you would be surprised at the mess that was on the floor. Apparently, the amount of oil it will hold depends on how long a person is willing to let it drain. Perhaps this can account for SOME of the differences between how much the manual says it holds, and how much individuals seem to be able to put into it.
   / BX22 engine oil level question #4
The manual is wrong on this one..Buy an extra quart or two.
   / BX22 engine oil level question #6
I always put 3 quarts in mine[SAME ENGINE] ,has worked for over 800 hours now.
ALAN
10ft QA Snow Pusher (A49251)
10ft QA Snow...
2004 JOHNSTON STREET SWEEPER (A45679)
2004 JOHNSTON...
2019 KENWORTH T880(INOPERABLE) (A48992)
2019 KENWORTH...
2009 Audi Q5 SUV (A46684)
2009 Audi Q5 SUV...
2015 MITSUBISHI OUTLANDER SPORT (A48992)
2015 MITSUBISHI...
John Deere Suitcase Weights (A49251)
John Deere...
