Backhoe BX22 Backhoe Dolley info Requested!
   / BX22 Backhoe Dolley info Requested! #1
drcollie
Northern Virginia
Kubota BX22
I've got all the supplies to make that BX22 Backhoe Dolley in the garage, and "Bernie" took it off his website that I had bookmarked. Guess the original post was about 6 months ago? I suppose I could scratch-build it, but the photos and concept were good (and why re-invent the wheel?) so if anyone has them saved and could forward them to me it would be MOST appreciated. E-mail to drcollie@cox.net.
Orignially, the photos were at :
http://home.comcast.net/~mburnickas/
Thanks much....I hate to leave the backhoe outside in the weather and the dolley is going to be the only way to keep it inside the garage.
-Duane C,
Virginia
   / BX22 Backhoe Dolley info Requested! #2
Was just there!! On the left side menu go to BX22. Then at the top of the next page Loader Dolly!!
   / BX22 Backhoe Dolley info Requested! #3
<font color="red">Just for the sake of making it easier: </font> Backhoe Dolly
   / BX22 Backhoe Dolley info Requested! #4
Great pictures - the only thing I don't understand is what you make the longer dolly so long. Wouldn't a much shorter dolly just to support the contact points work?
Yankee Bill
   / BX22 Backhoe Dolley info Requested! #5
I just posted the link for someone's convenience , It isn't my pics.
   / BX22 Backhoe Dolley info Requested! #6
Hi TBN users!, I made the BH roller/dolly using the 2 by 4's because it was also to be used for a loader dolly & tiller. You could make it shorter if not being used for a loader. You do not want to make it too short, as it might want to tip. It was just a quick thing I made that seemed to work well. Now the process on HOW to use it too sometime.
Any suggestions or mods to it, let me know. I will update as you wish.
   / BX22 Backhoe Dolley info Requested! #7
I missed the original post but glad to see this! I have several customers that hate to leve there machines out but haven't a good way to store them.
   / BX22 Backhoe Dolley info Requested! #8
The biggest thing in the process I feel is steps 6 and 7. I does take sometime to get used to doing it.
I will re-edit the page since I forgot to bold and underline somethings. Also I will add that you need bolts long enough to go through the (2) 2 by 4's, mounthing plate of dolly and though the bolt being used to secure it. If you use a bolt to long it will hit the wheel(s); hence, you will not be able to turn the dolly in a all directions.
I will add this note to the page within 45 minutes. Sorry I forgot to add that.
***The link is in my home page on my signature. Do not worry I will not remove it! /forums/images/graemlins/smile.gif I might add more detail or other tips, tricks etc down the road. If you guys want me to make a webpage for ya let me know. I have like 50 or 75 MG left. Plus it is fun...
   / BX22 Backhoe Dolley info Requested! #9
Thanks Mike B. Excellent job. Now I need to get busy making my dolly.
   / BX22 Backhoe Dolley info Requested! #10
All updated guys. I just bolded some text, used numbers on the steps & added a note on the top of the page about bolt length.
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2019 TRITON TRAILER ALLMAND MAXI LITE 45 GENERATOR (A52472)
2019 TRITON...
KUHN SL124T LOT NUMBER 63 (A53084)
KUHN SL124T LOT...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
