BX22 & 48" King Kutter. Busting out the torch?
   / BX22 & 48" King Kutter. Busting out the torch? #1
jnjpream
Berthoud CO
BX22
This may be better off in the mods section, but I'm hoping some other BX owner has dealt with this already..
I got a good deal on a King Kutter 48" rotary cutter (sorry, Rotary Kutter) but when I go to hook up, the lift arms will only take it 6-8 inches off the ground and I can't even get the top link short enough to connect.
Am I hooking it up wrong? It seems pretty straight forward..
Is there any reason I can't move the hitch points lower? It wouldn't really change the load on the lower links. But the top link, if it gets high enough to actually lift to mower off the ground, may see a little more stress because of the different leverage point.
   / BX22 & 48" King Kutter. Busting out the torch? #3
You could lower the pins for sure.My landpride rc 15 came with 2 locations for pins depending on whether you have a sub compact or a compact.Also the frame work lowered which changed the location of the top link.
   / BX22 & 48" King Kutter. Busting out the torch? #4
I had the same problem. Just lower your pins about 4" this should do the trick.
   / BX22 & 48" King Kutter. Busting out the torch? #5
No need for the torch. add two pins in place of the bolts that are nearest the deck. you may need to drill out the holes as I did on mine. It worked perfectly after the new pins were installed with no other modifacation. My tractor was a B7610
   / BX22 & 48" King Kutter. Busting out the torch? #6
Did you attached the PTO shaft prior to this?
The PTO shaft could be binding and causing the relief valve to pop open.
You may need to have the pto shafts( male and female) shortened bya machine shop to allow it to raise fully.
leon:thumbsup:;)
This thread is a year old.. I just punched new holes ~5" lower and put in another set of pins.
Tires (A50322)
Tires (A50322)
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2019 KENWORTH T680...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
