BX2000 FEL Fast dump problem
   / BX2000 FEL Fast dump problem #1
DaveNH
Fremont, New Hampshire
BX2200
It just up and quick working.
Worked fine last time I used it - a couple of weeks ago.
Today I went to do some work and it won't even click over.
Even after an hour of use the value won't go to fast dump.
I disconnected all the lines and reconnected them making sure they were tight.
Lines are warm so there is fluid pumping through them.
Slow dump works but it's too slow when moving snow.
Float, up, down, curl and slow dump work ok, it 's just the fast dump
that isn't.
Any sugguestions? /forums/images/graemlins/confused.gif
   / BX2000 FEL Fast dump problem #2
Re: BX2200 FEL Fast dump problem
Mine did this also, and I found that I had to disconnect and reconnect the quick disconnects to cure the problem. Make sure that they are fully plugged in and that you relieve all pressure before disconnecting them and reconnecting them. I believe that something is hanging up in the valve mechanism after this happening to me 3 different times. Might be interesting to compare serial numbers of the valve to see if there is a possible manufacturing defect that is causing this.... Mine is a 4 way valve on a BX-22... I posted about this problem this past summer..... /forums/images/graemlins/frown.gif
66'' skid steer bucket (A53421)
66'' skid steer...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
7 Battery Backup Surge Protector (A51695)
7 Battery Backup...
2014 KENWORTH T800 MIXER TRUCK (A53843)
2014 KENWORTH T800...
Two Floor Matts (A51695)
Two Floor Matts...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
