wojnaroski
What rpm’s do you all use when cutting grass. I have been using around 2500.
After break in 50 hours go full throttle for mowing machines. During 50 hours break in go full throttle and then back off just enough that you can tell you backed off a bit, not much but a bit. Took me years and many, many Kubotas to accept and believe and do this but now is the way I run all diesel powered Kubotas that are used for mowing grass.
I mow at high RPM when the situation dictates.
Tall, heavy grass, max RPM (or for whatever the RPM is for the implement is listed on the tach, like 2500/540/1000 -- usually will have arrows or indicator marks for each). My BX2200 doesn't have a tach, so it's just max throttle.
Low grass or a simple manicure, medium RPM to save some fuel.
Remember: Always start an implement at a low RPM, then slowly raise it up. Never start an implement at full bore.
