TC 40 Chuck
OK I'm sure that you all think that I'm nuts - but....: I already had a 72" tiller for my TC40A, so thought that I'd try it on the 1870. Had to trim the PTO shaft and move the mounts on the tiller to the max inboard to keep the drive shaft from (length) binding. Having to trim only 1" off of the PTO shaft I can still use the tiller on the TC40 if I need or want to. So - I ran this combination and it WORKS. It's about all the Kubota wants to do, but if I didn't try to be too aggressive with the depth and speed it works. I ran 2000 rpm and of course low range. Moving slowly you could prepare a garden plot from a weedy field, with a couple of progressively deeper passes. I did manage to stall the engine once - was trying to move too quickly. I DID NOT try to operate this with a bare tractor, I had the FEL on. It felt a bit light on the front end, so not sure if it would keep the front wheels down without the FEL on the tractor. If I get crazy next weekend, I'll remove the FEL just to test and will post results. If I had to actually BUY a tiller, for only this tractor, I certainly would NOT buy a 72" - but a 60" would be perfect. Hope someone here finds this info useful!
