Mowing BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade?
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #1
wrooster
Platinum Member
Hi,
Hopefully a simple question.
What is the hole diameter of the blade used on the BX1860 54" MMM RCK54-23BX?
Or asked another way...
What is the correct Gator Mulcher blade for use on a RCK54-23BX?
The Messick's site says the OEM for the BX1860 54" MMM RCK54-23BX is Kubota P/N K5351-99040. I gather via Google that the K5351-99040 is an 18 5/8" blade with either a 7/8" [0.875"] or a 29/32" [0.906"] center hole diameter. Not sure if the the links via Google are correct though. On the Oregon website I see no direct Gator blade cross reference to this size/hole diameter blade, but I do notice in reading the excellent forum here that several BX1860 54" MMM owners are using Gator blades. I have also read that some folks have had to drill out the blade hole (real fun time drilling into a hardened blade!) or alternatively have used a spacer/collar to get a 1 1/8" [1.125"] diameter hole down to the correct size.
Confusing things even further is Baileys site, which indicates that the proper hole is 23/32" [0.719"] and their FAQ says "Yes, this is the correct blade for the [ RCK54-23BX]...
Bailey's - 18-5/8" Gator Mulcher 3-in-1 Mower Blade for Kubota 54" Mowers
Summary:
Any idea what the correct Gator Mulcher blade is for my BX1860 w/RCK54-23BX?
Thanks!
Jim aka the wrooster
ps:
Since this is my first post I believe I am required by local custom to add a picture of my pumpkin:
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #3
On 10/11/2006, 'kubotabilly' posted "The gator # is 90996". He replied to my request as to what part # fits the 54" decks. I have not yet purchased any, so don't know how they fit
96-748 is what I used for my 54" Fine Cust which I believe is the same as yours:
18-5/8" Gator Mulcher For Kubota Replaces K5617-34330
Ok, this appears to align with the Bailey's site (i.e., 23/32" center hole) but seems to disagree with some other sites that insist the center hole on the 54" RCK54-23BX is 7/8".
I'm not sure the fine cut (RCK54P-23BX) and regular (RCK54-23BX) decks use the same spindles, although that would make sense.
I don't want to have to drill out the center holes in the blades, or have to ship them back at my cost.
Hmmmm.
I guess the only way to be absolutely sure is for me to pull the deck out from under my 1860, flip it up, and measure the shaft diameter.
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #5
All I can tell you is that I got them, I put them on, and they work great. :)
And I think the blades numbers are the same if you compare the OEM ones.
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #6
Hmmmm.
wrooster - I just bought the 96-748 blades through Bailey's for my RCK54-23BX and they don't fit (too small center hole). I measured the spindle and it comes up to 7/8", so now I'm having a local machine shop bore the hole. I do believe I've seen posts on here where people have bought the 18 5/8 blades with a 1 1/8" center hole and just added a bushing to make them fit; lots easier than having to get the hole bored out...
I hope this helps anyone with an RCK54-23bx (regular cut) mower thinking of buying Gator Blades.
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #7
I have the 60" deck for my BX23. I get the 91-438 or 90-987 and have to use the bushings. (see sig)
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #8
I just ordered some gator blades for my RCK54-23BX, the 18 5/8" blades with 1 1/8" hole. Now I need to make my bushings.
I have seen people saying to make the bushing they cut up a cat1-cat0 adapter, but isn't it a cat2-cat1 lift arm bushing that goes from 1 1/8" to 3/4"?
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #9
Cat 1 is 19mm or 3/4"
So many cross reference charts are wrong ,that I don't
buy anything without seeing it first !
   / BX1860 54" MMM RCK54-23BX -- What hole size /or/ PN Gator Mulcher blade? #10
Thanks OrangeRidge.
I went to the dealer and measured them, the CAT1-CAT2 was 3/4" ID and 1 1/8" OD. I should have the blades later today or tomorrow morning.
2022 Wacker Neuson LTV6 S/A Towable Light Tower (A49346)
2022 Wacker Neuson...
3/8" Universal Quick Attach Plate (A47371)
3/8" Universal...
KENWORTH T800(INOPERABLE) (A48992)
KENWORTH...
Allis Chalmers 185  2WD Tractor (A49251)
Allis Chalmers 185...
Pull-Type Lime Drill (A49251)
Pull-Type Lime...
2015 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A49346)
2015 Caterpillar...
