BX1850 w/ RCK54P-23BX Fine Cut Deck -want to add Mulch Kit
   / BX1850 w/ RCK54P-23BX Fine Cut Deck -want to add Mulch Kit #1
shrekbelly
Orange Believers,
would like to seek your input on my bx deck questions. am renovating property in fall with turf type tall fescue.
i intend to paint the underside of my new deck with slip plate, not on tractor yet. will cut at 3.25 to 3.50 inches hieght of cut. would like to purchase a mulch kit for my rck54p-23bx and will always be cutting at a slower ground speed (dictated by number of turns and terrain).
how much is this mulch kit? stock no.? Or, would i be better off, just running a high lift "GATOR BLADES?" i am a believer in mulching.
upon reviewing the rotary mower manual, i see -my deck is for the the bx2350 and larger. previously, i was told that the 1850 would handle this deck and my dealer did not mention anything to the contrary. did i err in purchasing this deck? my novice impression of this tractor is that it has plenty of power . . . was told, that kubota doesn't rely on blade tip speed as a quality of cut factor.
thanks for your time and attention, i appreciate any input. shrekbelly
   / BX1850 w/ RCK54P-23BX Fine Cut Deck -want to add Mulch Kit #2
I have a BX1850 with the 54" fine cut deck and have no need for a mulching kit. I am very happy with the cut. I did inquire about it when I purchased the tractor and the dealer said the the mulch kit is just a couple of extra baffles and different blades. He suggested that I try cutting with out it first and I am glad that I did. I have a pretty nice lawn with a sprinkler system and it doesn't leave many clippings if I keep up on the mowing. Tip!!! I cut in circles so that I blow the clippings to the center and I keep cutting them over and over also if the grass is long or heavy keep the shoot cover pulled up. I always mow with mine pulled up, I just drilled a hole in the plastic and hooked a bungee cord to it and I can let it down if I need too. As far as cost I can't remember how much but I do suggest cutting a few times without it first, you will be surprised and you can always at the kit later.
P.S. I was a city boy so I like to keep my grass looking nice. I always use to bag it.
   / BX1850 w/ RCK54P-23BX Fine Cut Deck -want to add Mulch Kit #3
I have the same setup as you and bought it without the mulching kit at first. After a few piles of cut grass on the lawn (when it was kinda deep), I bought the mulching kit. It is a plastic insert and 3 new blades. I can't remember the exact cost. Maybe $160? Anyway, it installed easy and works great. No problems at all. I cut at ~3000 rpm in low range. Every once in a while, it leaves a little grass on the right side but I can just overlap a little more on the next pass and it disappears.
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
JOHN DEERE FC20M LOT NUMBER 55 (A53084)
JOHN DEERE FC20M...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
