drag_slick
Bronze Member
A few months ago at 310 hrs my oil pressure light would flicker at idle, other than that no strange symptoms. Replaced the sender and it still does it so we put a gauge on it. 7.5 psi at idle and 25psi at 3100.
Dumped the oil and cut the filter apart and there was a bunch of metal shavings so the engine was yanked and dropped the pan off. Looks like the main bearings are shot, the crank can be wiggled about 1/8".
I've owned the tractor since new, and all maintainence was done at recommended intervals. After the initial oil change I switched to synthetic and have been running Amsoil 5w-30 diesel oil.
Just trying to figure out what happened here and if I did something to cause it. Unfortunatley the tractor's a year out of warranty so I'm guessing I'm outta luck.
Edit... guess I could be more specific about usage...
Bought the tractor in 2006 with a loader and tiller. First two years was tilling yard, tree rows and a couple gardens and loader work, tractor sat the winter indoors and was started maybe once a month to keep a charge on the battery.
In 2008 I bought a 50" 3pt snowblower and spent a lot of time snowblowing as the winters the last two years have been crazy. The tractor sits inside in an unheated garage, and I always let it warm up until the temp needle is up almost to the middle before heading out, and the summers are still mostly loader work.
Any thoughts?
Any thoughts?
