Oil & Fuel BX1830 fuel filters
   / BX1830 fuel filters #1
BobG116
North Central Ohio
BX1830
I recently changed my fuel filters and used JOHN Deere metal filters at a cost of $6.10 each. kubota filters cost $9.47 each. Talking to the head mechanic at Kubota and he said the metal filters were not good. He said they could cause a problem. He didn't say what. I figure if john Deere uses them on there diesel tractors why not on my kubota. I'm not a mechanic but if there was such a problem someone on this site would surely have an answer.
   / BX1830 fuel filters #2
I wouldn't worry about it. Personally if I weren't going back with the OEM filter I'd just pick one up from NAPA for $4 instead of Deere for $6.
thanks for your comeback and the NAPA price sounds good. Thanks again,Bob in Ohio
   / BX1830 fuel filters #4
What JD filter did you use JD makes one as a water trap. It is just a 100 mesh screen. If that is what you have then you minimal filtering and you will be having injection troubles in no time.
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
KJ 45'x25' Metal Garage (A50121)
KJ 45'x25' Metal...
14" Pipe Ditch Lift Pump (A50121)
14" Pipe Ditch...
2016 Ford Explorer...
