BX1830 - 50 Hour Service
   / BX1830 - 50 Hour Service #1
gearbox
Kubota BX1830D
Greetings! I've been reading for a while...lots of great information...thanks. I'm getting ready to do my 50 hour service & have a question about the transmission oil strainer. The manual says to rinse it with non-flammable solvent. Can anyone shed some light on a specific product to use?
Thanks.
Jeff
   / BX1830 - 50 Hour Service #2
</font><font color="blue" class="small">( Greetings! I've been reading for a while...lots of great information...thanks. I'm getting ready to do my 50 hour service & have a question about the transmission oil strainer. The manual says to rinse it with non-flammable solvent. Can anyone shed some light on a specific product to use?
Thanks.
Jeff )</font>
Welcome to TBN, Jeff /forums/images/graemlins/laugh.gif
I just did 50 hr service on my bx1500. Based on other posts I found here, I decided to use brake cleaner. It comes in an aerosol can - I picked some up at the local NAPA for about $3.
A couple words of caution though. First, there are flammable and nonflammable brake cleaners, so make sure you get the nonflammable type - it is printed on the can. I don't really know what the difference is, but, like you, I noted that nonflammable was specified in the manual. Second, when you remove the strainer, be very careful of the rubber o-rings - there are two, and they are very delicate looking. One came out with the strainer when I removed mine - I assume the other remained seated in the hyd line since I never saw it and there are no leaks.
Also, just for the record, there was virtually no debris or metal shavings on the screen - I sprayed the heck out of it anyway and blew it dry with compressed air. Also, the hyd fluid looked like new when I drained it. Still, I wouldn't have been comfortable deferring either procedure.
Thanks, I never thought of brake cleaner. Thanks for the heads-up on the o-rings too.
   / BX1830 - 50 Hour Service #4
The only reason I can tell for the non flammable stuff is that it is being used on a part that will be in contact with hot fluid. Just a guess though. I have cleaned mine twice in the 500 hours I've had it. Both times I used regualar mineral spirits. The flammable kind. I did allow it to fully evaporate after I cleaned it though. I haven't noticed any problems due to this. My hydro hadsn't blown up or blown out any seals. SO I am curious if anyone out there has a better clue as to why they want only non-flammable cleaner.
   / BX1830 - 50 Hour Service #5
</font><font color="blue" class="small">( ..............SO I am curious if anyone out there has a better clue as to why they want only non-flammable cleaner. )</font>
Product liability... if you get hurt using a flammable liquid cleaning the part, Kubota could be held liable, or a more direct one word answer...... LAWYERS!!!!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / BX1830 - 50 Hour Service #6
That's probably closer to the truth than my guess. Unfortunately /forums/images/graemlins/frown.gif
Well, here's the follow-up. I did the 50 hours service at 43 hours & it went pretty smooth. The oil & transmission filters were a bit tough to get off. Either there wasn't any oil applied to the seals or magilla gorilla tightened them. Either way, the oil filter was the most awkward. I didn't have to take off the FEL to change the filter either. The transmission strainer was not bad either. I had metals pieces there, so the strainer definitley did it's job. The o-rings (at least the outside one) was a little tricky, but not bad. As far as the non-flammable solvent goes...I used mineral spirits...they're combustible, not flammable so they should be fine to use. I made sure to blow the strainer off with compressed air afterward. Thanks for all your advice!
10x16.5 Tire Assembly (A52748)
10x16.5 Tire...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
3pt Ditcher (A50121)
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
Case IH 2608 8 Row Corn Head (A52349)
Case IH 2608 8 Row...
