BX1800
   / BX1800 #1
Anonymous Poster
Epic Contributor
Seriously looking at a BX1800 after owning (happily) a JD 445 for six years. Looking for the diesel and 4wd upgrades as the bigger part of my rationale. I cut a little over 4 acres and I don't need a loader. I would probably buy a 60" MMM and front hyd blade for snow and a box blade or rear grader blade for moving dirt around. I will eventually buy a PTO sprayer as well.
Would I be any better off with the BX2200 for the extra $$$ since the lighter weight of the 1800 will make it easier on my lawn? Does the MMM have a mulching option?
Repeat: No loader in my future, cutting about 4 1/2 flat acres with the 60" MMM.
Any BX1800 owners opinions would be very much appreciated in addition to other comparative advice. Thanks in advance.
Craig
   / BX1800 #2
I can't answer all of your questions, but I'll give you my input. I was looking at the BX1800 also. Ended up with the BX2200 because it was only $300 more. Was it necessary? Probably not, but I'll never know for sure. For mainly mowing the BX1800 should do just fine.
There is a mulching option for the MMM. I have the mulching kit installed on my mower. It is around $200 and consists of some steel shielding to improve airflow and block the exit. I installed it myself - about 1 1/2 hour (unexperienced time) and around 15 holes to drill. That Kubota steel on the mowers is tough to drill through! I am very pleased with the mulching kit - haven't felt the need to purchase additional mulching blades though. The standard blades are working just fine.
   / BX1800 #3
You may want to reconsider a FEL after getting the price on a front blade. When I bought my tractor , I was quoted $1750 for the front blade as opposed to $2400 for the FEL.
   / BX1800 #4
Instead of using a front blade for snow, you may want to consider a 3 pt snow blower. I picked up a new Pronovost Puma 54 inch unit for a $1000.00, just another option to think about.
I would go for the BX2200 for the few extra $$, just for the peace of mind and the future resale value. If you by a FEL you will find a 1000 uses for it.
Have fun.
Tom
   / BX1800 #5
I have had a BX1800 for about a year with FEL and rear blade. Have yet to find anything reasonable that I could not do that another 4 HP would have done. Limitation is definitely traction. I have filled the rear tires (turf) for added traction and stability. If you don't get a loader you probably won't miss it, but.....anyone who has ever had one won't ever have a tractor without one. I love my bota.
Gerry
   / BX1800 #6
how tall on average is your grass, when youve cut it using the mulching kit? does it slice and dice the clippings or leave a wet glob of grass on top? i have a bx2200 enroute this week...
   / BX1800 #7
I have a BX 1800 with a fel, 5' landscape rake and a 54" MMM and am absolutely satified with the smaller BX. In my case there was a $1400.00 difference in cost between the BX's.
The BXs biggest limitation is its weight and traction; it will spin all four wheels when put to task.
   / BX1800 #8
I've got the BX1800 w/ the 54" MMM. Woods GTO40 tiller and Woods rear blade. No problems or limitations encountered. Right now, there is a factory rebate on the BX1800, but not the BX2200. The difference in price for my configuration was about $1400.
Just to give you a comparison, the BX1800 w/ 54" MMM was priced at $7950 after the rebate. I could have exchanged the 54" MMM w/ the 60" for additional $100 but for my needs the 54" MMM was a better fit.
Jim
   / BX1800 #9
Craig,
No FEL??? Do you have any need for a 3PH? If not, consider a ZTR mower with a pull behind boom sprayer.
If you are going to get the tractor, I would spend the extra $300 and get the BX2200. Then again, I have learned my lesson with buying tractors without FELs. I'll never buy another tractor without a FEL. It's just too darn useful. I gar-ron-tee you will find 1000+1 uses for the FEL once you have one.
   / BX1800
I definately want a 3PH PTO sprayer and the ability to use a box blade. I have a Befco brodcaster and a Vassar landscape rake I use with my 445 that I will be able to use with the BXxx00. It seems like the BX is set up more for the loader and I have become pretty fond of my front blade with hydraulics. By the time I outfit the BX with a hydraulic front blade, the loader is almost as cost effective.
Thanks for the advice. The dealer I am talking to gave me a first round price of $10,000 for the 1800 w/ 60" MMM and $10,500 for the 2200 with the same deck. The Loader is $2,350. I'm pretty sure he'll deal a little bit. he didn't even mention the rebate on the 1800, which is listed as $300 at Kubota.com
Craig
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
RIGID TOOLBOX (A52472)
2012 MACK PINNACLE CH613 FLAT TOP DAY CAB ROAD TRA (A51243)
2012 MACK PINNACLE...
UNUSED AGT H15R EXCAVATOR (A51243)
UNUSED AGT H15R...
7021 (A50322)
7021 (A50322)
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
