Re: BX1800 won\'t start
Can't give any specific advice...
But would try turning the key to the start position and moving all the levers, including the HST pedal, back and forth. Hopefully, doing this would tell you which area was the problem.
For example, you need the range selector to be in neutral, and also the HST pedal to be centered in order for the starter to be given permission to turn the engine over.
Also, you may need to be sitting on the seat. My BX does not have a seat interlock, buy yours might.
Do try moving everything while holding the key in the start position. This might tell you where the problem is...
Afterwards we can wait for those who really know how to help to give better advice.
Don't forget to report back on the solution to the problem. Hope it comes easy!
